Toshiba EStudio 202L Missing Part?
  • JLSam
    • Jun 2015
    • 605
    This toshiba prints even with the right door fully open. The right door switch isn't working. I found the Part Number for the LGC BOARD.
    But for the LIFE of me, I CAN NOT find that damned right side door switch in the parts manual.
    Maybe it's missing?
    Any help would be awesome. Thank you.
  • gliderider
    • May 2015
    • 131
    Re: Toshiba EStudio 202L Missing Part?
    Doubtful anything is missing. There are only two switches that are interrupted when the right side door is opened (without duplexer). You have a push switch on the right side. Those are everywhere across the Toshiba line. Then there is the right door/ front door open switch which is accentuated by a toggle at the door and via a connecting rod to another toggle which is where the push switch is located. Never had one fail. This switch is connected to the LVPS.
    • gliderider
      • May 2015
      • 131
      Part location is in Ribon is Front Frame Asm
      Item# 108
      • JLSam
        • Jun 2015
        • 605
        Thank you all for the quick responses. Thank you!
