e-studio 256 connection limit
  • bruce 49dcs
    • Jan 2017
    • 140
    my customers 256 says can not print due to connection limit. I think its a network issue but the IT guy is blaming the copier they are in the midle of replacing all the pc,s in the office
    thanks for any help
  • jonwill
    • Jan 2017
    • 10
    Re: e-studio 256 connection limit
    thanks for any help
    Change port on print driver from WSD to a standard tcp/ip port or change 08 code and increase max users.
    • bruce 49dcs
      • Jan 2017
      • 140
      sounds like what I thought I told the IT guy to change the port to a tcpip and havent heard back yet can you tell me the 08 code number so i dont have to go through the long list of codes in my book just being lazy I guess but thank you very much for the input
      • jonwill
        • Jan 2017
        • 10
        Changing port type will fix the problem , Probably why you haven't herd back from IT guy , 08-3765 default is 10 max is 20.
        • bruce 49dcs
          • Jan 2017
          • 140
          you where right great job thanks
