e2540c k developer issue
  • didi2005
    • May 2011
    • 401
    Used e2540c where the color machine not using color at all, only print black & white. The problem now is the developer worn out very fast, less than 10k print the developer will depleted and need to replace...
    Since the machine is not running color, 08-2486=0, 08-4546=0, color registration is disable, if enable call for service will sign on due to all 3 colors developer is not good.
    Already cleaned or swapped CLN-DRUM-ASY drum unit where I suspect due to main charging, but problem still persist. Wonder is it caused by the color registration disable? Or customer print too much solid black print out?
  • clint@clintsimonsen.com
    • 124
    Re: e2540c k developer issue
    Check the blanking lamps, (03) 325 326 off the top of my head door switch needs to to jigged too. Quite a common issue with that model,
    Sent from my ONEPLUS A6000 using Tapatalk
