E Studio 200L CF60 error code
  • yormets
    • May 2009
    • 336
    Machine was working. I pulled the PCU/Dev unit and cleaned up the drum blade area. Reinstalled and now I get a CF60 error as soon as the paper hits the registration roller. There is no bind in the waste toner transport area. Everything is turning easily. There are no clogs. I see an indication about an auger lock switch but see no "03" input to test it. It mus be mounted somewhere on the back of the machine. Is there anything else that I did that could cause this? Never ran into this issue before where it wasn't the auger bound up.
  • BTech21
    • Jun 2019
    • 12
    Re: E Studio 200L CF60 error code
    Try, going into 03, then press "start", then "fax" (fax light lit), hold 1. The box G should not be highlighted. If it is there is a switch in the machine that detect the auger lock. Also make sure the auger can move freely front to back.
    • yormets
      • May 2009
      • 336
      Thank you for pointing out where to test the switch. I overlooked it. I will know soon what it is.
