Developer issues TOSHIBA e 550
  • vanngoc
    • Dec 2008
    • 10
    I'm used copier machines TOSHIBA e 550 of the machines is Developer fly out at the drum. Please ask him on the forums on how to overcome the Developer from the airport . Thanks
  • ToshibaTech
    • Apr 2007
    • 580
    Sounds like either a bias problem on the developer unit or just worn out developer. Is the developer going everywhere inside the machine, or do you just feel some developer on the printed page (i.e. sandy feeling.)
    I will not give you service manuals or firmware.
    • decimal
      • Aug 2006
      • 75
      First, what are toner & developer ,OEM or ..? Are you sure they have no problem ?
      • razzer
        • 34
        check that the transport auger is not clogged or not turning.
        • atudorica
          • Oct 2007
          • 79
          also check:
          main charge
          drum ground
          temp sensor for drum
          • Baphomet
            Copier Technician
            • Aug 2008
            • 293
