ES 2051C RADF
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] ES 2051C RADF
    Hi everybody,
    need an urgent help.
    After installation of a new Toshiba ES 2051C, machine print ok & copy ok on platen glass.
    When I try to do a copy on the RADF machine indicate "PLace Doc Feeder in the down position".
    Can someone help please
    Can someone help on how to test the RADF position sensor?
    Rgds
    Jean Paul
  • gliderider
    • May 2015
    • 131
    Re: ES 2051C RADF
    The actuator that detects the position of the adf is located on the top left rear of the copier. When you raise the adf you should see it. If a document is on the adf tray and the adf is in the raised position if you depress the actuator that message should go away. That should inform you that the sensor is working properly. Make sure that the adf is not missing a small tan rectangular piece of plastic that the actuator should come in contact with when it is in the down position.
    • jeanpaul
      • Mar 2009
      • 117
      Re: ES 2051C RADF
      Hi, Thanks for your reply,When there is a document in the Adf tray and the Adf is in the raised position, even I press the actuator the msg does not go away. (I try on an old machine, the msg go away).I change the ADF still getting the msg.I also change the 2 sensors of the actuator, same msg.Thus is a new machine from the box. Is there any enablement configuration that need to be change in NVM?RgdsJean Paul
      • gliderider
        • May 2015
        • 131
        Re: ES 2051C RADF
        I would also look at where the adf connects to the copier and check for bent pins. Also what model adf are you using?
        • jeanpaul
          • Mar 2009
          • 117
          Re: ES 2051C RADF
          Hi,
          I check where the adf is connected to the machine, all pins seen ok on the plug.
          I also try an old Adf which was working ok on another ES 2551C, same problem on my 2051C
          On the new ADF box it is written MD-0105.
          Do you think we should do a Firmware upgrade?
          Thanks & Rgds
          • jeanpaul
            • Mar 2009
            • 117
            Re: ES 2051C RADF
            Originally posted by jeanpaul
            Hi,
            Thanks & Rgds
            Sorry on the box itis MR 3024
            • gliderider
              • May 2015
              • 131
              Re: ES 2051C RADF
              If the firmware is out of date I would definitely update it. The most current is 2190.
              • jeanpaul
                • Mar 2009
                • 117
                Re: ES 2051C RADF
                Hi, just update the firmware.
                Problem solved.
                Thanks a lot for your help
                Rgds
                Jean Paul
