Toshiba e-studio 810
  • Vesigoth
    • Mar 2008
    • 133
    I'm having several problems with this machine. The fuser is not heating up and I'm not getting any code even after 10 minutes of "warming up". After reinitializing the hard drive in function 2, I reset all connectors on both hard drives and on main board. Also cassette # 2 and LCC are not shown on the display although the paper lift motors do lift the paper. I load a document on the ADF and the document is taken in and spat out of the ADF but the scanner doesn't move although it does move when power is turned on. I've replaced the fuser unit and the IH board in front of the fuser unit and no help. If you've seen these problems before please help.
  • ToshibaTech
    • Apr 2007
    • 580
    I had a similar problem, it was the HDD. Had to replace it. In my case you could actually hear the HDD clicking so it was pretty easy to narrow down. Your case might be different but I had the same symptoms with mine.
    I will not give you service manuals or firmware.
    • Vesigoth
      • Mar 2008
      • 133
      Hi. how you're doing. Thanks for replying. I don't hear it clicking, just an electronic beep or 2 @ initialization. also there are 2 HDDs. can I put a 550 HDD ?
      • atudorica
        • Oct 2007
        • 79
        hdd connected to sys boartd is for the copier
        hdd connected to GL 1020 is for printing scanning functions
        hdd from e550 should be ok
        check firmware level (08- 900 codes)
        • Vesigoth
          • Mar 2008
          • 133
          Toshiba e-Studio 810
          Thank you both for the help. I'll replace the HDD and post back with results. Thanks again.
          • whatadish
            • Dec 2008
            • 10
            ck drum thermistor
            try checking drum thermistor connector...i seem to remember a problem with these and forgetting to plug in the thermistor after drum replacement
            • whatadish
              • Dec 2008
              • 10
              same issue...my fault
              yeah...had some unrelated issues on an 810 and while swapping lgc pwb installed bc ram upsidedown. After installing the chip in right and putting the pwb back into the doaner machine it exhibted the exact same problems you described. New bc ram because it wouldn't reflash, and problem solved.
