toshiba e-studio 2550c fax forwarding
  • bruce 49dcs
    • Jan 2017
    • 140
    so i networked a 2550c today and everything is working well except when i go to top access under admin, registration, then fax forwarding I cant put in remote 1 file path for the forward of faxes
    the whole section is grayed out.n it is set to fileshare but nothing gives me access to put in a file path
    thanks in advance
    bruce
    • 8178
    Re: toshiba e-studio 2550c fax forwarding
    Under Admin, Set Up, Save As File, have you checked"Send Documents Directly to the Storage Path"?
    Destination "Use Network Folder Destination"?
    • bruce 49dcs
      • Jan 2017
      • 140
      I think you are talking about save to file for scanning I have to check that I didnt know save to file would effect fax forwarding that would do it ill let you know
      • Thayer
        • Dec 2017
        • 107
        Does it have a HDD or SSD?
        That could be the case, that machine could have either one.
          • 8178
          Good point! The SSD version of the now discontinued e2550c was not very popular and had a much more limited feature set. I was referring to the HDD version.
