Toshiba E-Studio 28 Network Reset
  • banksters
    I am looking for information on how to restore the factory settings for the network. I had this unit connecting to a domain server in my office but when the office closed, I got rid of the server and now want to set up the copier in my home office without a domain server. I can get the ip to update but can not get the domain/workgroup out of the unit and the computer can not see it on the network eventhough I can see it on the router and can get a ping from the ip that it is pulling from the router. Any help would be appreciated
  • tsbservice
    Field tech
    • 8082
    Hold down 0 and 8 keys simultaneously and turn on the power.
    Enter 693 then start. That should initialize NIC back to factory default.
    Set IP address via control panel admin tab, ping machine from PC, open web browser to set other things.
    • atudorica
      • Oct 2007
      • 79
      information above is wrong!
      you may have GL 1010 or GA 1040
      you may both set up by entering machine IP as address in your web browser
