toner recycle system fills up! es 810
  • Papo
    • Oct 2008
    • 36
    Every 10k to 20k we have to empty out the toner from the recycle resovoir and conduits. Theres no obstruccion or malfunccioning components is this a common problem?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    Check the auger that moves the toner into the developer that it is not missing part of its spiral.
    • ToshibaTech
      • Apr 2007
      • 580
      There is also an 08 code to make the machine use more or less recycled toner. It's in the S.H. .. Sorry I don't have one on this laptop.
      I will not give you service manuals or firmware.
      • Papo
        • Oct 2008
        • 36
        Checked the spiral no breaks
        [quote=Baphomet;55852]Check the auger that moves the toner into the developer that it is not missing part of its spiral.[I wonder if there is a modification for this dv unit seems like the auger that feeds toner to the toner auger does a poor job flaking toner to toner auger therefore creating the back up and cd-3 code]
        • Papo
          • Oct 2008
          • 36
          Yeah i increased waste toner dispense and decreased new toner drop rate Do you know of any modification that may correct this problem this is one of the first generation 810s almost 3 million copies on it!
          • tsbservice
            Field tech
            • 8082
            Check out this info:
            unitedtechsonline.com • View topic - estudio 650
