color streaks
+ More Options
Posts
  • MAW
    • Mar 2019
    • 11
    color streaks
    Don't know much about the Toshiba e studio 2550c I'm having a problem there a black and color streak near the bottom of the copy. I cleaned the LED unit check the drum units This is a refurb about two day ago this just started happening the customer after cleaning the copier ran 25 copier problem cleared up than a black streak show at the bottom the copier leaving me to think that it the drum unit. So left it at that came back to the and the streak had reappeared.ebsmicas@gmail.com_20200220_171300.pdf
    Re: color streaks
    Originally posted by MAW
    Don't know much about the Toshiba e studio 2550c I'm having a problem there a black and color streak near the bottom of the copy. I cleaned the LED unit check the drum units This is a refurb about two day ago this just started happening the customer after cleaning the copier ran 25 copier problem cleared up than a black streak show at the bottom the copier leaving me to think that it the drum unit. So left it at that came back to the and the streak had reappeared.[ATTACH=CONFIG]45023[/ATTACH][ATTACH]45024[/ATTACH]
    wow no valuable info given
    how may pages on PM part?
    OEM Toner/drums?
    did you clean the ITB cleaner?
    what EXACTLY was done before you delivered to customer?
    completely cleaned?
    new drums/belt/fuser?
    PhilB. "The Dentist"
    • abc mfp
      • Aug 2019
      • 12
      Re: color streaks
      Wow, labour charge $155/hour~~~
      Since the streaks happen on both B/W & Color, I will check transfer belt unit especially the cleaning side...
      • MAW
        • Mar 2019
        • 11
        Re: color streaks
        This copier was brought from a company California and shipped here so I don't know the service history of this copier the transfer belt and cleaner blade are new there is OEM products in it. The page count on the color 74115 and black 63845
