GL-1020 Print Problem
  • Dan
    I set up a GL-1020 in an eStudio 550 and when you print to it it only prints every other page. If you print Duplex it works fine but if you print single sided it only prints the odd numbered pages. I've tried both the PCL and PS drivers on Server 2003, XP and Vista. Any help would be appreciated.
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    Have you tried from different applications?
    • mhmsaqer
      field Supervisor
      • Jun 2007
      • 83
      before doubting the controller try the follwoing :
      • try the low level printing (lpr) printing order fom DOS.
      • try to capture the PRN file and try it on another machine and then you can find the suspect.
      good luck.
      Be happy for a moment - this moment is your life.
      Omar Khayyam
      • Dan
        I have tried from multiple programs, there is no change.
