Imagistics cm3530 (Toshiba 3511) scanner help?
  • CopyDawg
    • Dec 2008
    • 74
    Hi,
    I am trying to figure out how to get my Imagistics cm3530 to scan to my computer. The copier and printer are working fine, but I cant seem to get the scanner to work. It will scan to E-File...but not my computer. Is there something special I have to do to get it to send a file to my computer? I have Vista, so I had to download the drivers from Toshiba.com....would that have anything to do with it?
    Any help would be much appreciated!
    Thanks!!
    CopyDawg
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Vista is a pain to setup this way. First is to turn of the smb signing. second setup an account on the copier with a password. then set the machine to scan to the machine using the account and password.
    This is overly simple steps to do but you get the idea.
    • CopyDawg
      • Dec 2008
      • 74
      Thanks. Question, do you have to connect the copier via Cat 5 cable to get the scanner to work, or can it work through USB? (It is only connected to one computer)
      • ivovb
        • 695
        Scan to SMB works via network. e.g. you need RJ-45 and cat 5/5e cable connection.
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • atudorica
          • Oct 2007
          • 79
          if vista security is too much pain use scan to email
          you need smtp from you internet service provider
