Toshiba e-studio 55
  • makaule
    • 74
    Toshiba e-studio 55
    Changing drum blades every ~20K copies becouse it starts jumping and makes thin vertical grey line o every copy ? Have more 55/65/80 copiers and have to change drum blades after every ~150k copies. But this one is crazy.. Any ideas ?
  • smiley
    • Aug 2008
    • 615
    are you using oem blades?
    there is no glory without sacrifice
    • makaule
      • 74
      Not OEM blades and not OEM toner. But with OEM is the same.
      • makaule
        • 74
        Found the problem - it was becouse of loose flywheel.
        • ivovb
          • 695
          Thanks for feedback.
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
          • makaule
            • 74
            it could have been not only becouse of flywheel, room temperature was about 10 deg. celsius - in mornings told to turn and hold heat up 24/7 and no more opened window condicioneering becouse copier was standing near it.. Used to go everyday all last week and now 2 days without problem.. Hope i'll return there only for PM.
