I have a estudio 200 that is cycling power. Comes on and then shuts off. Have replaced the power supply. Any ideas?
Estudio 200 cycling power
Unfortunately it is well known issue that in 100% in my cases leads to main PWB. Yes it is quite expensive. You can try re-flash firmwares and you can achieve temporary good effect but finally you will get my conclusion!
BRI'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.Comment
kuno
