e-studio 151d System error [H4-00]
  • apok
    • 14
    I've a problem with small Xero e-studio 151d. On a screan appears "System error [H4-00]",. Any one have idea what is wrong?
    Thanks for help.
  • ivovb
    • 695
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • ToshibaTech
      • Apr 2007
      • 580
      C/I/0/I code 14. If it doesn't reset probably a blown thermostat on those piece of crap fusers. Also have seen the lamps some, mostly thermostat. If it has many miles on it I'd just replace the fuser. Man I hate those machines.
      I will not give you service manuals or firmware.
      • apok
        • 14
        I've replace the fusser and error still appears. And I have no idea how to use the C/I/0/I because when I enter this sequence nothing happens
        • ivovb
          • 695
          Clear → Density select → Clear→ Density select is for service mode.
          Check code 26-30 and set to 0 - CE mark support control OFF
          Try surge arrest power source.
          BR
