Botched Firmware Update
  • Signmaker
    • Aug 2025
    Our Techs tried to do an update and something went wrong, we are unable to get past the start up screen or anything no 08, 05 or anything just stops and hangs...
    Copy Machine
    Estudio 350
  • ToshibaTech
    • Apr 2007
    • 580
    Try 3+Clear #3 then #2, reload firmware again (4+9), then 08-947, 08-690(use a 2)
    I will not give you service manuals or firmware.
    • Travis06
      Tech.
      • 193
      If the above post doesn't work, your looking at having to use the recovery jig that loads the bare minimum and then you can flash with USB.
      • Signmaker
        Where to get a recovery Jig
        Where can we get a recovery jig
        • ivovb
          • 695
          The jigs are special toshiba tool, available for toshiba partner companies. You can order like spare parts, but you will need programmer, too.
          BR
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
          • Signmaker
            Updating Jigs
            Does anyone have an extra set of updating jigs around.. they would not mind getting rid of... signman@windstream.net
            • mohsen3310
              • Sep 2008
              • 14
              can we update firmware whit pc?
              • fireater
                Repair God? not quite
                • Apr 2006
                • 253
                yes but why would you?
                but is sounds like the hdd is corrupt or dead.... try the proceedure for hdd replacement like toshiba tech said and do the firmware again if that fails then try hdd replacement...
                iget into assist mode
                Turn ON the power while [3] button and [CLEAR] button are pressed simultaneously
                do option 3
                then do firmware--\
                Turn ON the power while [4] button and [9] button are pressed simultaneously.
                NOTE Past experiances with firmware on ebridge one units... do all the firmware EXCEPT the nic fiirmware........
                when it completes initialize the new firmware....l;et machine come to full ready .. like wait a few minutes..make a copy..... (let the hdd finish the partitions)
                THNE go back into 4+9 and do ONLY the nic
                then reinitilize firmware...
                this virtually ELIMINIATES the dead nic problems....... I know i killed a few on these before i did it this way
                I fix copiers ...Well Sorta
                • mohsen3310
                  • Sep 2008
                  • 14
                  firmware files
                  can you send me es 45 firmware files?
                  some as this
                  - Program data sysfirm.tz
                  - Fixed UI data uidataF.tz
                  - Common UI data uidata0.tz
                  - 1st language UI data uidata1.tz
                  - 2nd language UI data uidata2.tz
                  - 3rd language UI data uidata3.tz
                  - 4th language UI data uidata4.tz
                  - 5th language UI data uidata5.tz
                  • fireater
                    • Apr 2006
                    • 253
                    Some as this
                    - program data sysfirm.tz
                    - fixed ui data uidataf.tz
                    - common ui data uidata0.tz
                    - 1st language ui data uidata1.tz
                    - 2nd language ui data uidata2.tz
                    - 3rd language ui data uidata3.tz
                    - 4th language ui data uidata4.tz
                    - 5th language ui data uidata5.tz
                    now im confused e-45 or e-350?
                    • emujo
                      • Jun 2009
                      • 3009
                      E45 requires Win 2000 and parallel port and FSMS (toshiba utility), or pre programmed EEPROMS mounted on update jigs. Good luck finding either, MFP is over 10 years old. EMujo
