Toshiba 5506 different print size ration than older 5560
  • donthomaso
    • Aug 2025
    5506 print size smaller than 5560, the width of the print is smaller and more compressed, 2mm difference than older 5560, this results in a OCR code that another system cannot interpret correctly.
    Is there any way of changing default width ratio for prints or is this just a machine issue?
    We have tried different drivers and also used the same older driver for 5560 with same results.
  • Blizzoo
    • Aug 2013
    • 611
    Re: Toshiba 5506 different print size ration than older 5560
    You can try a Image Dimensional Adjustment as per the manual section Settings/Adjustment. Maybe wasn't setup properly at the first initialization?
