E-studio 5506AC Meter count from Service menu
  • venluckey
    • 36
    Tester for a Reseller of copiers,
    Is there a way to get the Meter count from the Service menu if the machine will not come to ready. I have had various problems with toshiba's and need to have a count on them. Was wondering if there a 4 digit code to show B/w and Color meters, like you could do before the E-bridge.
    Thanks.
  • arnh79
    • 468
    Re: E-studio 5506AC Meter count from Service menu
    There's a couple options I can think of. Both are done from FS Mode - 30 List Print Mode:
    1. 114 will print out the total counter (but if you're having big issues you may not get a sheet out.)
    2. Insert a USB stick and then type in 214 - that will export the counter info on to the USB (This let's you skip any issues you may have with printing anything)
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • venluckey
      • 36
      Thank you, I will try the USB method next time.
