When you are adding contacts to the address book using TopAccess, and you need to put a pause within the phone number (after the number and before a long-distance authorization code), how do you do it?
At the walk up panel you would press the monitor/pause button and the pause is represented with a dash "-" but if you put a dash in the number in TopAccess then the fax doesn't recognize it as a pause and just ignores it. I have tried commas, but no luck either.
Thanks if you can answer this.
