ADI to SATA
  • riyadh hossainbd
    • Dec 2015
    • 239
    ADI to SATA
    Hi everyone,
    Is their any other possible procedure that's not listed in the bulletins/service manual for putting a normal type SATA HDD drive in this machine? The correct procedure could not be followed as the last owner took the ADI HDD with them.
    Is the only option to get a new ADI HDD??? Surely their must be some work around for this..
    Thanks in advance
  • rspicer
    • Oct 2015
    • 97
    Re: ADI to SATA
    I haven't touched a Toshiba in a couple years, but as I remember, you can change a SATA machine to an ADI machine, but not the other way.
      • 22808
      Re: ADI to SATA
      i'm sure the main board doesn't have SATA connections on it. The SATA drive uses different wiring than ADI. So no it's not possible.
        • 7881
        Re: ADI to SATA
        What is the model # of the copier you are working on?
        Generally, the answer is no.
        • riyadh hossainbd
          • Dec 2015
          • 239
          Re: ADI to SATA
          Es256 se
            • 7881
            Re: ADI to SATA
            Originally posted by riyadh hossainbd
            Es256 se
            You need a Toshiba proprietary SED-HDD. No off the shelf HDD will work.
