Toshiba e347csl squeaking loudly when printing
    • 8193
    I have a e347csl in as a loaner copier and it is squeaking loudly when it prints.
    Fortunately, the copier is in a room by itself.
    Anybody remember why the print engine on these copiers squeaked?
    The customer has a e356 with 400k on it that they got for free from somewhere. I do not feel like trying to fix it anymore so I put in a loaner and a quote on a new e330AC.
  • tsbservice
    Field tech
    • 8008
    Re: Toshiba e347csl squeaking loudly when printing
    Crappy fuser unit?
      • 8193
      I have a use one to try.
      Thanks,
      • Vincent128
        • Sep 2015
        • 349
        There is a small gear train that runs the fuser, consists of 3 gears on a pivot type engage (drives in one direction and lets go in the other). Its in between the print engine and the copier shell they stuck around it. It's been a squeak maker and a pain for me for years. There is no easy way to get anywhere close to the stinking thing without framing the unit. I normally remove everything easy then tip the machine at an angle and use the skinny tube / metal rod / get oil to drip on the shaft aerobics to get it to stop but it will come back without the proper lube.
          • 8193
          This is only a loaner copier but I can manhandle it by myself into customer locations so I would like to keep it working. Thanks!
          • djbass
            • May 2008
            • 165
            The image drums on those start to seize up as they get old and it could be an indication one is on it's way out, easy to test by removing one at a time and closing the cover to see if noise disappears. I've also had squeaking coming from where the transfer belt shafts make contact with the earth/leaf springs on the machine body.
            No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
              • 8193
              Next time i am onsite, I will try that.
              I am not in a hurry to fix this. It is a loaner copier and it is time for the customer to upgrade to a new one.
