3560 background
  • deputydogg
    • Nov 2015
    • 172
    3560 background
  • arnh79
    • 468
    Re: 3560 background
    This is a trip down memory lane! Most common cause of background on that series is optics. Clean the mirrors and then adjust the 05 exposure settings. (I can't remember those codes any more) It could also be that the drum is just worn out.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • deputydogg
      • Nov 2015
      • 172
      Re: 3560 background
      • tsbservice
        Field tech
        • 7977
        Re: 3560 background
        I think codes for manual and auto exposure were 1 and 5. Did you clear slit glass? Check T/S wires and block for arcing that may be the cause. Don't forget to clear grid and main charger also.
        Good luck.
        • riyadh hossainbd
          • Dec 2015
          • 239
          Re: 3560 background
          Change drum , otherwise 05 ✓ 41✓increase value
