Toner chip
  • MacTavishLK
    • Nov 2020
    • 67
    Toner chip
    Hi,
    How can I diable toner chip in toshiba 256 , 257 , 2309 , 2508 copiers? Please help me.
    Thanks.
    Re: Toner chip
    Originally posted by MacTavishLK
    Hi,
    Thanks.
    For what purpose do you want to disable the chips?
    • MacTavishLK
      • Nov 2020
      • 67
      Re: Toner chip
      Dear Phi B.
      I used 2nd quality toner cartridges for that copier models. but there are not toner chips for any cartridges. Therefore I have to buy chips separately. Chip cost is much. Can you tell me to disable toner chips for that copier models?
      Thanks.
        Re: Toner chip
        Dear Phi B.
        Thanks.
        Not familiar with this brand but I've never heard of being able to disable the chip thru any machine setting.
        • MacTavishLK
          • Nov 2020
          • 67
          Re: Toner chip
          Dear BillyCarpenter
          Please check PM
          Thanks.
            Re: Toner chip
            Dear BillyCarpenter
            Please check PM
            Thanks.
            I read your PM. Why not just post it on here? Here's the answer to your question: NO. I can't find any of that information for you. I told you that I don't work on this brand. I know ZERO about 'em.
              • 8097
              Re: Toner chip
              Hi,
              Thanks.
              No such setting is available on Toshiba copiers nor is it in the manufacturers best interest to provide one.
                Re: Toner chip
                Dear Phi B.
                Thanks.
                Not possible.
                Drop the crap toner.. I don't recommend crap toner in ANY machine.
                • MacTavishLK
                  • Nov 2020
                  • 67
                  Re: Toner chip
                  Not possible.
                  Dear Phil B.
                  We can 08#499#0 for disable the toner cartridge chip in toshiba 255 copier.. Can you help me to find the disabling chip code for toshiba 256 , 257 , 2309 , 2508 copiers.
                  thanks...
                    Re: Toner chip
                    Dear Phil B.
                    thanks...
                    you've been told it's not possible.
                    • MarioTech
                      • Jul 2020
                      • 48
                      Re: Toner chip
                      Mac It's not possible on newer models to do this, the money you save on generic toner you will burn on washed out developer material and hours of cleaning the depleted toner plus developer inside the machine plus clutches replacement. I've had clients use generic on these particular Toshibas before getting their business and I can confirm that you will save money by buying OEM toner, taking a unit into the shop to completely disassemble it to blow out all the magnetic carrier on the right cover plus all the parts replacement will be more that the OEM cost.
                        Re: Toner chip
                        I know folks on here hate reman cartridges so don't shoot the messenger:
                        I have refilled over 200 Kyocera color carts and haven't had the first problem. Zero. Zilch. Notta.
                        • MarioTech
                          • Jul 2020
                          • 48
                          Re: Toner chip
                          That works fine with Kyoceras as they are mono component, when it comes to carrier like Toshibas it'll not work as it has to blend in with the carrier and create a toner/carrier mix with proper density to not be depleted or washed out. I've done Kyoceras as well after I vacuum the old OEM toner the aftermarket will kick like a goat and keep running.
                            Re: Toner chip
                            Understood. Here's a picture of the toner and chip that I use for Kyoceras:
                            • MarioTech
                              • Jul 2020
                              • 48
                              Re: Toner chip
                              [ATTACH=CONFIG]47753[/ATTACH]
                              Awesome thank you for sharing!
