In need of Toshiba e-Studio 206L firmware
  • Teserak
    • Feb 2021
    • 1
    Hello. I picked up a used Toshiba e-Studio 206L MFP but was given a F100 error on startup. I did a filesystem scan of the HDD and it failed all tests. I then tried a reformat of the HDD and ran the tests again which completed successfully, but obviously the drive is now wiped and needs the system software put back on the drive.
    Does anyone have the firmware for this particular copier or have any insight on how I should go about replacing the disk data?
    Thanks in advance
  • aalex_bom
    • Jan 2008
    • 214
    Re: In need of Toshiba e-Studio 206L firmware
    Hi Jonathan,
    PM sent
    good luck
