Toshiba 282 firmware update error
  • lankamx
    • Feb 2021
    • 3
    I try to firmware update Toshiba 282 copier When the equipment was shut down(power cut) during firmware updating. Please any one help to treat this error.
    Re: Toshiba 282 firmware update error
    are you sure the firmware was in the proper place when you were updating?
    did you try to update again?
    being an enduser where did you get the firmware?
    do you have the service manual?
    • lankamx
      • Feb 2021
      • 3
      [QUOTE=Phil B.;1686211]are you sure the firmware was in the proper place when you were updating? not sure..i tried update all firmware as service manual.
      did you try to update again? yes many time..
      being an enduser where did you get the firmware? from online..
      do you have the service manual? yes i have
        [QUOTE=lankamx;1686223]
        Ok...
        On the USB drive.. where is the firmware files?
        Are you sure you have the proper firmware files (current)?
        Did you contact the seller of the firmware?
        • billmcwho
          • Jul 2020
          • 22
          I lost power during a firmware update on this model and it blew out my system board!
