Toshiba E-Studio 2051c Firmware Update
  • Guest
    [Error Code] Toshiba E-Studio 2051c Firmware Update
    Hi !
    I discovered your forum some days ago and he help me a lot with the code to access to the Boot Screen.
    I made a clean SVRAM clean and formated the SDD. The photocopier stuck on the F902 error and F520 if i press the 08 code on boot.
    I want to perform a reinstall to try. Can you send me a link for download the firmware and tell me the procedure to reinstall it ?
  • Guest
    Re: Toshiba E-Studio 2051c Firmware Update
    Update :-)
    I've received the file for update my firmware but now i've a problem. The screen tell me when I make 4+9 Copy Signature File in USB Storage
    The Manual service say "Data files are not stored in a USB device. "
    The problem came from the USB Key ?
    UPDATE2:
    I found the firmware on the USB Key (yeahhhh) but now he tell me "Invalid Signature" on the System update en System OS. The SSD can be dead ? Can i replace it with any SSD ? Thanks
    • Blizzoo
      • Aug 2013
      • 608
      You may need the FW for the SSD insted of HDD regarding that signature issue
