Copy & Scan
    • 8178
    Copy & Scan
    I have had two separate law firms ask me today to be able to configure their eBN2 copier V1512 FW to be able to simultaneously copy and scan their documents to multiple network folders.
    I am aware of the "Storage" function that becomes available when you press the Copy icon. This lets me scan to Remote 1 and Remote 2 but I need 10 folder destinations.
    I told the customer if I was able to find a solution it would require Pro Service $ to program. They balked at that but I did not budge.
    If you try and create a Template, as soon as you check Copy, Scan is greyed out so that is not going to work.
    If you try and use the Home+ button to create a new one touch it does not permit me to combine a copy and scan function.
    Ideas?
    Thanks,
  • clint@clintsimonsen.com
    • 124
    Re: Copy & Scan
    Try using templates, with remote2 you can set up a different folder for each template
    Sent from my Nokia 8.3 5G using Tapatalk
      • 8178
      Re: Copy & Scan
      ... FW1512 will not permit you to select more than one Scan Agent at a time per each Template created.
