ECC Cloud Connect event codes and waste toner
  • Vincent128
    • Sep 2015
    • 349
    Is there a current compilation or list of event codes on FYI, I am not finding one anywhere or does someone have a nice list they have compiled ?
    Is there anything we can monitor to let us know when the waste toner bottle is near full?
    I only see D30F Waste Toner Full, and it's a bit too late when it's full.
  • Thayer
    • Dec 2017
    • 107
    Re: ECC Cloud Connect event codes and waste toner
    You should be able to create a policy, to monitor the waste bottle percentage. Just like you would for your toners.
    04- ECC Guide-Policies, check in this guide.
    • Vincent128
      • Sep 2015
      • 349
      Please note what codes I should monitor for waste bottle percentage because there is none that I know of.
      I already have various policies for just about everything else but waste toner seemed to only have an "Waste toner empty" event.
      Input from another site that I have not fully researched due to time, but it "may" be D32E with 08-3699 turned on for a near full event - input?
      • Vincent128
        • Sep 2015
        • 349
        Soooo...it seems on the 5005ac and 5015ac series machines they added a code 08-3699 (nearly-full notification setting) for the waste toner and it's default is off - I am fairly certain the 5055c machines whom have no such code just always displayed when it was nearly full.
        I have turned this code on for 22 systems and will see what happens and am monitoring event code D32E as I am lead to believe that event is the nearly full display event - time will tell as I have had no other feedback or findings that I have found.
        Other things that I normally have policy for :
        08-8981=192
        08-5155=4
        08-5810-0=3
        08-5810-1=3
        08-5810-2=3
        08-5810-3=3
        08-9891=0
        08-9602=our dealership name
        08-9700=our phone number
        08-6011=1
        08-8523=0
        08-9299=0
        event codes
        D321
        D322
        D323
        D324
        D301
        D302
        D303
        D304
        D341
        D342
        D343
        D30F
