08 code(s) for decommissioning
  • juliano
    • May 2011
    • 44
    Hi all
    I recall an old thread where someone knew the 08 code(s) for decommissioning a client machine......ie: clear down ALL client information.....stored IP, directroies, email addresses, fax numbers etc.....Can anyone help?
    In a perfect world it ould re-set it back to factory OEM settings (counters still correct though)......I do realise that there will still be legacy data on the HDD
  • Vincent128
    • Sep 2015
    • 342
    Re: 08 code(s) for decommissioning
    Do you mean the HS-74 Revert factory Ini HDD and/or HS-73 secure erase HDD in Section 9 of the SM ?
    There is also 08-8615/6 decommission Mode in section 12 of the SM but that's more like a lockdown of the OS until unlocked.
      • 8079
      "that's more like a lockdown of the OS until unlocked". Does that mean the copier will not operate but the OS is still there?
      Would not "Factory Default" under User Functions/ Admin work?
