Toshiba 1370 or Lanier 7313
  • cantfixit
    Does anyone have the maintenance codes for this copier or error codes. This machine goes out after so many pages and I had the codes and lost them. can anyone help me before Saturday January 27, 2007
  • Wild Bill
    • Jul 2005
    • 774
    What codes do you need?
    Izzy
    • St Anne's
      Dear Wild Bill, did you find the maintenance code for the Toshiba 1370? I have a problem with contrast, I cannot set it darker. The drum was replaced by a Tech who did not know how to reset this. As you know it is an old machine but in excellent condition.
      • JOEYSULLIVAN
        • 20
        how to adjust exposure settings
        Turn on the machine while holding down the 0 and 5 number keys at the same time. This will put you in service mode. enter 1, then print key to get exposure reading for manual copy exposure setting. Use the 1 and 3 keys to adjust number higher (lighter) or lower for (darker). If you want to adjust auto exposure, enter 5 instead of 1, after getting into adjust mode. Also, 0 in adjust mode calibrates developer. Of course, holding the C key and 8 simultaneously gives you the error code. Thats while the machine is on and the wrench showing, simply hold down C and 8 together. I love these little tanks.
