4508 KD-1059
  • tnrtt
    • 156
    4508 KD-1059
    Have a strange LCF problem. Load both sides of the LCF and boot up. Shows both sides full. Run 1 copy, then right side shows empty. Reboot and will show full again. Key in 5 and will run all 5, then show empty after completion. Carry a feedhead with me and swapped it, no difference. this was at end of day when they were closing. disconnected LCF and said I'd be back. Error history showed a lot of C1B0 and C180 codes. I'll research it this weekend. Any idea's would be appreciated. I have a KD-1058 I can put on it if it's not an easy fix. Thanks
    • 8324
    Re: 4508 KD-1059
    ... did you re-flash the copier's firmware and all accessories to latest V1610 ?
    • tnrtt
      • 156
      Re: 4508 KD-1059
      Yes. All my stuff has current firmware check for new versions weekly.
