281c
  • TTL
    • Dec 2008
    • 127
    281c
    Hi,
    In one Toshiba E-studio 281c, she was block every time, and I format the disc, but she still the same, then I change the disc and reload the firmware. But she still frozen. And now I can't access to some codes, like 05+396, 05+395, and others that now I don't remenber.
    She is very unstable, sometimes don't initialize the network, other's don't make copies (we press the start and nothing occurs). I'm almost crazy with this...
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    is the memory "original toshiba" or did you pop out to the computer store to get the upgrade? try another hdd... get a new 80 gig western digital give that a try (i had a bad stick of generic ram once..... weird problems)
    I fix copiers ...Well Sorta
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      when replacing the hard drive did you do the following
      1. Replace hard drive
      2 3 + clear power on option 3 start
      3 power off
      4 0+8 power on
      5 690 start 2 start
      6 reload firmware
      7 0+8 power on
      8 947 start
      9 redo 5
      10 power off then on
      • ivovb
        • 695
        Also if nothing helps it might come to SYS board replacement.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • TTL
          • Dec 2008
          • 127
          I think it's ok now.
          I change the hdd again, for one WD.
          But first I try another hdd from another Toshiba, and it it's always give me one error in the firmware upgrade in the Hdd part. Then I try the memory ram, with no result.. I try some codes too, firmware 2 version's....
          And finally the WD Hdd arrived, I try one last time change the HDD and worked..
          • ivovb
            • 695
            Thanks for feed back.
