Toshiba 477sl adf paper present sensor
  • Logged-on
    • Sep 2010
    • 197
    According to the (Lexmark) manual, the only way to replace the sensor is to order a new document feeder. Does anyone know if it's possible to get a replacement sensor for the paper present for these models or provide a part number?
    Thank you.
    • 8220
    Re: Toshiba 477sl adf paper present sensor
    The e477sl is a Toshiba/Okidata discontinued copier. You can only order the entire top deck assembly and not individual parts.
    It is a major effort to replace the ADF.
    Overall a poor design from Okidata who has now left the North American MFP marketplace.
    Your best bet is to try and find a used e347cs e477s to take parts off of.
    • Logged-on
      • Sep 2010
      • 197
      Sorry copied from the wrong call, it's a Toshiba-E-studio478s.
        • 8220
        .. this is a current model and you can order parts online from a wide variety of parts resellers including Lexmark.
        The e478s is also known as the Lexmark XM3250 and the MX622adhe
        Toshiba does not stock parts for Toshiba/ Lexmark's.
          • 8220
          From Toshiba Tec, these are all of the Lexmark part #s related to the ADF
          1 41X1329 ADF assembly 12 41X1335 ADF tray 13 41X2221 ADF cable cover 14 41X1321 ADF right hinge 15 41X1324 ADF cushion 16 40X9129 ADF left hinge 17 41X1318 ADF access door 18 41X1326 ADF roller 19 41X1325 ADF separator roller 110 41X1322 ADF restraint pad 111 41X1332 Flatbed scanner 112 41X1315 ADF cable 113 41X1316 ADF flat cable
          If what you are looking for is not here, you likely have to order the whole assembly.
