Toshiba E3555C Code CE40
  • AISI
    • 49
    [Error Code] Toshiba E3555C Code CE40
    Removed and cleaned Transfer belt, all Drums & Dev. units and image control sensor . Check 08 2528,2529 2530,2531 reset all to zero . 2531 will not stay on zero. Go back to [ 1 ]. I need help Please
    • 37422
    Re: Toshiba E3555C Code CE40
    You have posted in the wrong place. Post in the Toshiba Forum if you want all the Toshiba techs to see your question. https://www.copytechnet.com/forums/toshiba/
    • tee
      • Aug 2014
      • 79
      Have you tried checking the IQC shutter?
      It can cause code when it doesn't open completely.
