Dear all Pro,
I need your help, I'm facing problem from eStudio 600. the problem is F030. I try to upgarde the firmware become 329 by using USB storage device. but when falsh update LSR firmware is always fail. I try to update one by one. and in LSR, PFC, and Main engine firmeware is always fail. I try to update using JIG (PWA-DLM 350 48 MB) but still failed. Finally I change the SYS LGC and Main LGC including both NVRAM. Still cannot fix the problem F030 occured. when I try to entering 08 mode to check the firmware, "MACHINE INFORMATION ERROR, LONG PRESS ENERGY SAVER" appear. I have checked the cable, from SYS and LGC, also from PSU to SYS or LGC. everything is good (I checked using Multi tester).
Does any one having similiar this problem before, please if there is any advice or idea I really apreciate it.
thank you and regards
