Toshiba 1650 Strange Problem
  • Art Tech
    • 11
    I got a strange problem happens on my Toshiba 1650.
    When I used manual feeding to send paper from the side, the copy came out fine. But if I use the paper from bottom tray, there are 1 inch area from both top and bottom of paper just won't print. I repeated back and forth. This problem only happens at auto mode. Everything else seemed to work well.
    Anybody has any idea what would cause this?
  • jawir
    • Aug 2007
    • 107
    try to adjust the registration using 05 + ON code is 53.
    try increase and decrease, and see what is the result.
    regards
    • imaginGuru
      Tell your tech to change feed+reg clutches
      check part nrs. I think they're not interchangeable on this machine.
      imaginguru
      • ivovb
        • 695
        Check paper format setting for the cassette. If it is A4-R (or other one) and you are using A4 paper there will be cut-off of the copy on the top and bottom.
        08-53 is code for registration - this is leading and trailing edge of copy. Or I am getting terms wrong?
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • tsbservice
          Field tech
          • 8018
          Wrong paper size.
          Also these are well known for reg/feed clutch going bad.
          • Art Tech
            • 11
            Thank you all for your nice comments. The fix actually took 2 seconds.
            There is a square plastic plate on the side of paper tray. It was turned 90 degree to "Letter-R" instead of "Letter" position. Once it's set correct, the machine works great. I'm attaching couple of pictures here for future reference.
