eBridge Next Scan to Folder
    • 8479
    I found a good video which helps explain how to scan to folder on eBN1 and eBN2 copiers. eBN3 copiers have some unresolved issues with the lack of an XML format and importing templates from eBN1/ eBN2. You can now only clone from eBN3 to eBN3. You have to use the Template Data Conversion tool found under Maintenance/ Import to move Templates from eBN1/eBN2 to eBN3.
    Toshiba e Studio Scan to Shared Folder SMB on Windows 10 - YouTube
    In my latest remote install, I felt that I was inputting the Network Path, Login Username and Password correctly but when I pressed "Execute", I kept on geting an error message pop up saying that one of the three was in error.
    In the end, after multiple attempts, under Windows 10 Control Panel/ Network & Internet/ Network Sharing Center/Advanced Sharing Setting/ All Networks/ Public Folder Sharing/ Turn on Sharing was unchecked.
    ... so the error message can be misleading as to where the problem is.
    Essentially there is a whole Windows checklist described in this video that you need to configure before you attempt to configure a Scan Template.
