I am trying to setup an older Toshiba eStudio550 with a GL-1020 controller to scan to pdf to a network folder.
I created the share, example: \\Share\Share_Sublfolder and set the permissions I wanted on it and it continues to log that the specified network path is invalid, check destination path.
The unc path check and write permissions check ok. Has anyone else seen this problem with the GL-1020 controller? Any fixes or recommendations?
