ES 282 don't go ready!!!
  • minhkhanh
    • 60
    ES 282 don't go ready when turn on, it stoped at photocopy image screen.
    I could not enter 08 or 05 and 1 3 * mode.
    Help me please !!!!!!!!!!!
  • ivovb
    • 695
    1. Check fuser unit wiring for pressed wiring.
    2. Re-flash firmware.
    3. Re-set/change memory.
    4. Change HDD according to SH.
    5. Change Sys board according to SH.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • minhkhanh
      • 60
      BR
      So, must I do all there think or do one of there exactly?
      • tsbservice
        Field tech
        • 8008
        I will try to narrow down the problem.
        1.New HDD.
        2.Firmware.
        • minhkhanh
          • 60
          1.New HDD.
          2.Firmware.
          Thanks,
          I'm going to try
          My firmware is es 232 V330. Is that correct ?
          • tsbservice
            Field tech
            • 8008
            Yes.
            • minhkhanh
              • 60
              Yes.
              please tell me the way to up firmware step by step?
              and what problem take note at there progess?
              • minhkhanh
                • 60
                Hi every body!
                I tried to plug flash USB firmware in and turn on 4 9 , it take no action.
                I tried to replace the HDD and make sure it was ok.
                Any one help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
                • decimal
                  • Aug 2006
                  • 75
                  BR
                  I think you should replace SYS board if you can't re-flash firmware with USB .Do you have jig ?
                  • minhkhanh
                    • 60
                    no, I do not have
                    How could I get it, and how can I reflash
