I am wondering if anyone has a parts machine es 3055C (or compatible) with a functional cyan developer unit that I can buy. The customer's is locked up. I've completely disassembled and cleaned. Reassembled. Still won't turn properly. It's a food shelf so that's why I went to the extra measures. It seems that the 2555C/3555C are the same developers. Any help will be most appreciated. Thank you
Need eStudio 3055c developer unit (cyan)
Re: Need eStudio 3055c developer unit (cyan)
I have had problems with the developer units in the past. It is usually the gears on the end of the unit. They become worn and do not mesh properly. Cleaned the unit and replace all the gears. It should take care of the problem. Good luck
copyguy69 -
Thanks for your help.Comment
