toshiba e 230 drum developer regulate
  • nıke-reebook
    • 50
    which toshiba e 230 drum developer change modes begin ?
    You details explain...
  • Harry
    • 228
    quick answer
    05 200 for developer ajust 6 start to clear drum counter and relaeted counters
    have a nice day
    • nıke-reebook
      • 50
      which programme keys entrance ?
      • Harry
        • 228
        answer
        you have to switch one the copier with 0 5 hold then enter 200 and start after a fiew minutes display change to ajust mode so you can set manualy if you need to the other thing is switch on with start and 6 under the subscreen in display search drum unit and reset what you want
        • nıke-reebook
          • 50
          Thank you HARY
