Toshiba e-3511
  • Gabriel
    • Jun 2006
    • 141
    Toshiba e-3511
    Network Initializing takes so long
    If I reset the NIC board initialize in a minute but next time takes forever to initialize it
    Any help is welcome
    Regards
    Gabriel
  • atudorica
    • Oct 2007
    • 79
    sometimes you need to do 08-693 up to 20 times
    you will notice a button on the screen
    also I notice if you leave machine off for more then a minute will go faster online
    • Tos_Tech
      note + fac reset
      There's a service note about this problem: you should insulate the NIC from the iron frame. No iron parts, screws included, can be connected to the frame. Then reset your NIC by using the jumper on the NIC card.
      If this doesn't work i think you should change the NIC card.
      • ivovb
        • 695
        One more suggestion - check firmware and re-flash. These Toshiba models are very sensitive to power conditions. Also it might come to HDD change and firmware re-flash.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Gabriel
          • Jun 2006
          • 141
          Thanks for all the replies
          I did all suggestions but Had to replace the NIC board
          Regards
          Gabriel
          • ivovb
            • 695
            Regards
            Gabriel
            Today I have had the same case. Is it getting epidemic?
            BR
