Toshiba Estudio GL-1010 Document Controller, controller Os
  • mujahidsch
    • Aug 2025
    Hello Friends,
    I am facing Problem with Toshiba Estudio GL-1010 Documant controler. its OS is Crashed and machine Controoler not online. and "Start up controller" Messege is Displayed on the Screen. I need this controller OS. Please guide me the process how i eliminate this proble next time. Thank U.
    Regards,
    Mujahid
  • Hallmark
    • May 2006
    • 23
    I cannot provide you with the OS which you need to reload, but I can tell you the most common thing that causes it to crash is not shutting the controller down before turning the copier off. To shut down properly, your customer needs to shut down the controller from the control panel, then turn off the copier.
    • copyguy5
      Originally posted by mujahidsch
      Hello Friends,
      Regards,
      Mujahid
      The Toshiba Gl1010 Service Manual can be found at: Index of /protectedmembers/201519/GL1020prot
      Only download the manuals and Readme files. The other folders contain extracted Partition and Recovery Programs. Since these contain Executables some downloads can cause files to be corrupted. The Partition CD ROM can be downloaded as a complete image from:
      while the complete image of the Recovery CD ROM can be downloaded at:
      Hope this helps. Good Luck... Just a note: Patience is a virtue. Be aware it takes about 1 hour for the Partition/Recovery install. The setting list will pop out about 6 minutes after the restore is complete
      COPYGUY5
      • Xuanvinhqnam
        • Dec 2007
        • 51
        Can you tell me what are GL1020partv20.ISO and GL1020recov2125.ISO file ?
        • PTAI
          • Oct 2007
          • 38
          Hi copyguy5!
          This os version and recovery version can not setup on small HDD only support larger HDD 40GB.
          Mycontrolers have small HDDs (10GB ,20GB). please say with me where can i download the OS and Recovery to be used for the kinds this HDD.
          Win NT or Linux is ok.
          Thank a lot !
          Index of /protectedmembers/201519/GL1020partv20
          Index of /protectedmembers/201519/GL1020recov2125
          COPYGUY5
