Info on the Toshiba E35
  • Mopar Freak
    • 55
    We are considering taking on a maint. contract for a E35 copier. Are they reliable? Anything to look out for? Is the drum and dv unit all in one? I am waiting for the total count on it. Thx
  • ToshibaTech
    • Apr 2007
    • 580
    Good machine, two seperate units. Look at see if the drum is buffed about 2" from the rear if it is, it needs magroller "holders" or either a new DV unit. Fuser exit sensor prone to heat up and crack/turn brown. If it looks really bad it will probalby need a new sensor and harness which is also your thermistor harness. We have very few out with over 1mil fwiw. Look at your error history 08+start, 253. If you see CA1 codes that's your laser going out.
    I will not give you service manuals or firmware.
    • aalex_bom
      • Jan 2008
      • 214
      Originally posted by oronocova
      Good machine,
      08+start, 253. .
      you wrong ?
      you turn on and hold 08, press 253
      or you can printing log, turn on and hold 9 + start,press 101 or 102 then press "start"
      good luck
      • ToshibaTech
        • Apr 2007
        • 580
        Originally posted by aalex_bom
        you wrong ?
        good luck
        Yeah I guess by "start" I meant turn on... not hold down the start button. Hope he isn't standing by the copier holding all three for the last week or so...
