Toshiba E Studio 650 Service Code C59
  • Meach
    • Nov 2008
    • 128
    Just put a new tray lift motor in this and did not snap in one of the connectors on one of the boards.. Copier Powered up with the C59 code. I rest all the connectors but I still get the code. I do a 0,8 at power up but the tech mode is only on for a split second before the SC is displayed . How do I reset this code?
    Thank you
    This is a Toshiba ES 650, with the Imagistics ZD65 label.
  • Yellow Fever
    No reset for that code.
    according to the service book, C-59 is communication problem between main CPU and laser CPU.
    Check all connections between the LGC and PLG Boards.
    you might end up having to change one of those two boards.
    • Meach
      • Nov 2008
      • 128
      Thank you. I will double check those connectors between the boards. Perhaps I pulled a wire loose.
