e4525C with Fax Receive Forward
    • 8397
    A law firm with four paper trays and FAx board that has designated
    Tray 1 Letter-R - Fax
    Tray 2 Legal
    Tray 3 Cheques - Special
    Tray 4 Cheques - Special
    We have automatic change of paper source turned off. We do not want the busy paper tray 1 which often gets depleted with paper to accidentally pull preprinted cheques from paper Tray 3 or 4.
    I am thinking of enabling Fax Receive Foward to send incoming faxes to an email address. I am also thinking about about creating a Rule in Outlook so that incoming faxes are always sent to specific folder in Outlook.
    If there are five computers in the office, I would have to go to all five computers and create that Rule. Correct?
  • mojorolla
    The Wolf
    • 2660
    Re: e4525C with Fax Receive Forward
    You could also us Rule Based Printing in the print driver. Works great in a server environment. Just create and save your profiles and set specific programs to pull from specific trays:
    As to the fax forward email rule, if you are sending to five different emails, the rule would need to be created for each, I think. Can you send to a shared folder and just map that path?
      • 8397
      [ATTACH=CONFIG]61514[/ATTACH]
      As to the fax forward email rule, if you are sending to five different emails, the rule would need to be created for each, I think. Can you send to a shard folder and just map that path?
      All great ideas! Thanks,
        • 8397
        In the end the customer requested Fax Receive Forward to a single email address into the general Inbox. Not hard to do.
        I did not have to create any rules. Rules works well for me as I receive email meter reads every month all directed by a Rule to a folder called "Incoming Faxes". Therefore, I do not have to hunt though my entire Inbox looking for meter reads.
        This customer is a law firm and often receive faxes up to 200 pages long. I want under Document Print, print only "On Error".
        I thought Searchable PDF would be a great option for them but when I tick the OCR button, Document Print is defaulted to "Always Print" no matter what I did. Tried the same on two different copiers with the same result.
