E-166 C44 error code
  • k1ks
    • Jul 2025
    Good Morning..
    Can somebody help me with this C44 error? I already replaced the fuser assy, reset the 08-400 code.. but still c44 code appear.. .. Thus the power supply caused this error?
  • Harry
    • 228
    c44
    check if fuserlamp lit if not check for triac short or open of powersupply
    change powersupply if you have one
    good morning at all
    • k1ks
      C44
      Yes! Fuser lamp goes on (lit) after a few seconds it turns off and then C44 code appear..
      • Harry
        • 228
        c44
        You says to change fuser assy maybe there are bad thermistor on it check also distance to fuser roller.Bad Pins on the Side Connector.There no Probleme on the Powersupply i think its more a thermistor o harness problem
        Good Luck
        • mitsubee
          • 176
          Use 08-400-Key in 0-Start... try this before confirming the themistor.....
