what is the code CD10 refers to in e650 ? thanks alot for any help
e650
CD10 is cleaning brush motor abnormality. Check for locked up used toner transport augers and that the motor will run or try to run (03-115/165)I will not give you service manuals or firmware. -
Re: e650
What if im not getting anything when i run the 115? I have the augers all clear, used toner clear, developer seems heavy but it may just be me since I am looking for anything that may keep this thing from running.. it starts up fine.. when I try to make a copy , the developers start for a split second then it codes cd 10. this is on a 853 same thing code wise. Could it be a fuse? I am getting no response on a 03-115 at allComment
