toshiba e 45
  • smiley
    • Aug 2008
    • 615
    toshiba e 45
    hi guys is that true that a prblem automatic no display or shut down in this machine can solve by upgrading the system?
    there is no glory without sacrifice
  • aalex_bom
    • Jan 2008
    • 214
    have
    I think that you need to change P.S.B
    • smiley
      • Aug 2008
      • 615
      hi, that machine got power for just a minute or more after that a few copy made the machine display turns out.or totaly no display.
      • aalex_bom
        • Jan 2008
        • 214
        change SYS board
        and change S. Y. S. B
        • smiley
          • Aug 2008
          • 615
          so it means i need to chnge both of them power supply and system board?
          • aalex_bom
            • Jan 2008
            • 214
            yaeh
            • smiley
              • Aug 2008
              • 615
              [QUOTE=aalex_bom;75553]yaeh[/QUOTE
              thanks for help friend.is there any cheaper way to solve this problem.
              • tech07
                • Aug 2008
                • 409
                From experience, it's the power supply about 80% of the time and systen pcb the other 20%
                • smiley
                  • Aug 2008
                  • 615
                  can you tell me what specific part in power supply that usualy break down also in system board please.
                  • aalex_bom
                    • Jan 2008
                    • 214
                    PSB
                    If you turned off auto shut off and energy save function, The P.S.B could failed. you can repair and cheaper .
                    note the machine display turns out or no display but "copy" button and Main Power are light
                    you have to change Controll Panel Touch Screen
                    • smiley
                      • Aug 2008
                      • 615
                      no the machine turn black out but after you swicht off and on the main power swicht the machine will work again.
